JS781109
  • 8
Message 1 of 10
Help please with unstable wifi
Hi, I've had some issues recently with my wifi connection being unstable, most obviously shows up with video calls grinding to a halt or cutting out, also with online gaming. This occurs even if I'm pretty much next to the router.
I've called VM customer services, eventually got through to someone (30 minute wait!) they say there are no issues that they can see and so won't send out an engineer at the moment.
I use the Hub 3.0 in Modem mode with a Google Nest wifi system. I've discussed the problem with Google but they say there is nothing obviously wrong (had to do a full system reset with them).
I've attached my modem logs so if anyone can spot anything unusual I can then go back to VM...
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
259000000
7.3
40
256 qam
16
2
251000000
7.4
40
256 qam
15
3
267000000
7
40
256 qam
17
4
275000000
7.5
40
256 qam
18
5
283000000
7.6
40
256 qam
19
6
291000000
7.5
40
256 qam
20
7
299000000
8.1
40
256 qam
21
8
307000000
8
40
256 qam
22
9
315000000
8.4
40
256 qam
23
10
323000000
7.9
40
256 qam
24
11
331000000
8
40
256 qam
25
12
339000000
8.3
38
256 qam
26
13
347000000
8.4
40
256 qam
27
14
355000000
7.9
40
256 qam
28
15
363000000
8
40
256 qam
29
16
371000000
8.5
40
256 qam
30
17
379000000
8
40
256 qam
31
18
387000000
8.3
40
256 qam
32
19
395000000
8.3
40
256 qam
34
20
403000000
8.6
40
256 qam
35
21
411000000
8.5
40
256 qam
36
22
419000000
8.6
40
256 qam
37
23
427000000
8.4
40
256 qam
38
24
435000000
8.6
40
256 qam
39
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.9
20470
1841
2
Locked
40.3
16198
1837
3
Locked
40.3
26945
2463
4
Locked
40.3
26439
4496
5
Locked
40.3
31508
3505
6
Locked
40.3
39466
2795
7
Locked
40.3
39657
2622
8
Locked
40.3
46880
2939
9
Locked
40.3
42861
3097
10
Locked
40.3
59064
2844
11
Locked
40.9
61607
3218
12
Locked
38.9
65538
2979
13
Locked
40.3
66890
3142
14
Locked
40.3
86854
2974
15
Locked
40.3
93815
3789
16
Locked
40.3
95237
2922
17
Locked
40.3
118617
2574
18
Locked
40.3
118462
2904
19
Locked
40.3
136832
2910
20
Locked
40.9
130867
2794
21
Locked
40.9
143064
2450
22
Locked
40.3
153269
3057
23
Locked
40.3
175001
3816
24
Locked
40.3
167232
2918
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400020
44.3
5120
64 qam
4
2
46200086
44
5120
64 qam
3
3
25800176
43.5
5120
16 qam
6
4
32600045
43.8
5120
64 qam
5
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
11/02/2021 09:25:52
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 23:26:13
critical
10/02/2021 21:25:15
notice
10/02/2021 18:51:33
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 08:57:33
notice
09/02/2021 03:08:33
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/02/2021 03:08:33
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/02/2021 03:07:37
Warning!
09/02/2021 03:07:36
critical
09/02/2021 03:06:7
Warning!
09/02/2021 03:06:7
critical
09/02/2021 03:03:14
Warning!
09/02/2021 03:03:14
critical
09/02/2021 03:02:19
Warning!
09/02/2021 03:02:19
critical
09/02/2021 03:02:10
Warning!
09/02/2021 03:02:10
critical
09/02/2021 03:02:9
Warning!
08/02/2021 16:46:2
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2021 12:40:19
notice
jpeg1
  • 5.67K
  • 292
  • 964
Hero
Message 2 of 10
Re: Help please with unstable wifi
The signal levels are all OK, but there is rather more noise than one would like to see. And one of the upstream channels is not correctly set.
There are some more tests that you can try, but what happens with a device wired to the Hub? Thst would confirm right away whether the incoming service is at fault.
JS781109
  • 8
Message 3 of 10
Hi, thanks for the quick response. Difficult to be 100% sure but I have a google nest router wired to the Hub. The problem is there whether I run my wifi through the Google router in modem mode or the Hub in broadcast mode. That would suggest the problem is with the line right?
Any suggestions for what I can do to fix this gratefully appreciated!
jpeg1
  • 5.67K
  • 292
  • 964
Hero
Message 4 of 10
The Hub's WiFi is hopeless anyway, so that won't be a valid test.
There is a BQM test that you could set up, but that takes time.  The wired test will establish right away if the incoming signal drops.
JS781109
  • 8
Message 5 of 10
Thanks. Unfortunately my computer doesn't have an ethernet port so I can't connect it directly to the router, if that's what you mean?
I have tried setting up a BQM test but annoyingly the google router will not respond to ping requests, apparently, so I just get 100% packet loss. I think I would have to take the Hub back out of modem mode and disconnect the Google router to get it to work.
jpeg1
  • 5.67K
  • 292
  • 964
Hero
Message 6 of 10
Yes you would need to set the Hub back to router mode to set up a BQM, if the Google system won't cooperate.
You can get a USB ethernet adaptor for Windows or Mac.  It might be a useful investment.
Z92
  • 2.59K
  • 208
  • 416
Trouble shooter
Message 7 of 10
When was the last time you rebooted your router before you took these readings? We need to known whether the errors are current or historic.
  • 4.65K
  • 369
  • 1.15K
Message 8 of 10
As already stated you have a fault on the upstream, as noted by the 16QAM and PostRS errors.  All channels should be 64QAM.  You will need an engineer to sort this out.  Also, yes get some sort of adaptor for your computer to allow ethernet connections direct to the Hub, as VM insist on wired connections for testing.
JS781109
  • 8
Message 9 of 10
Thanks for the reply - I rebooted the router a couple of days ago as part of a factory reset on the Google Nest system.
JS781109
  • 8
Message 10 of 10
Thanks - I will go back to VM again and see if I can get them to come out. Unfortunately last time I spoke to them they were adamant there was no problem. Hopefully this will help convince them.
