Helen30144
Help error msg N27 cable not connected but everything is plugged in what can it be turned on and off se
Says cables not connected but all looks ok
what can it be
  • 5.63K
  • 462
  • 1.42K
Re: Help error msg N27 cable not connected but everything is plugged in what can it be turned on and off
Have you followed all this advice?
TV Error Code n27 | Virgin Media
Corey_C
  • 5.19K
  • 257
  • 446
Moderator
Moderator
Re: Help error msg N27 cable not connected but everything is plugged in what can it be turned on ...
Thanks for your post and welcome to the Community Forums, Helen30144,
Sorry to hear that you have been having TV errors,  Has the advice by @Adduxi been able to get this resolved?
Cheers,
Corey C
