Help! Wall socket removed by previous owner
Hello,
We have had to the self installation package arrive only to find the previous owner has removed the wall socket leaving us with just the black coax cable hanging loose from the wall.
I have traced this back and the black cable is directly from the brown Virgin box outside.
Does an engineer need to come over or can a barrel connector connecting the back cable and the white isolating cable provided be enough?
  • 3.5K
  • 566
  • 1.38K
Re: Help! Wall socket removed by previous owner
You'll need a technician.  Although it looks like (and in principle is) a simple coaxial cable, the nature of DOCSIS means that it is VASTLY more finicky than (say) a digital terrestrial TV feed, so doing a DIY cable repair (incidentally against the T&Cs you've agreed to) has a high chance of causing problems either for you or your neighbours.
You can try dialling it in, but may struggle to get through, but if you wait the forum staff will pick up your post and advise on what can be done.
I have no phone signal at the house, after waiting for 40 mins on hold outside local coop and live chat getting terminated decided to post on here.
Will wait and see if this gets picked by forum mod.
  • 6.17K
  • 459
  • 1.07K
Hero
A feasible option is for VM to post the missing isolator, just fit it to the cable and you can then do your installation.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
Risked another trip to the village and actually manage to speak to someone, got engineer popping over Thursday so hopefully should be up and running then!
  • 1.18K
  • 74
  • 143
Hi BHtaken,
Thanks for your post and for giving us an update on the engineer, please let us know how it goes after Thursday 🙂
If you need any further help we are here!
Megan_L
