danw_2020
  • 15
Message 1 of 13
Help! No internet connection
Hi everyone, have done some reading but can't find exactly the same issues as I have, so thought I should start a new post.
I woke up this morning to no internet connection through my Hub 3, but WiFi signal is fine. Devices can connect but cannot load anything, essentially. I have turned the router on and off, reset numerous times, unplugged everything and re-plugged - none of that made any difference.
I have logged into the router and, judging by what I've read online elsewhere, can't see anything alarming with regards pre and post RS errors etc. There are error logs (the usual ones that everyone has - timing sync failure, RCS partial service, no ranging response etc.).
I have run the diagnostic test through the router, which returned this result (see image) - so there is obviously an issue, despite no service outage being reported in the area and all Virgin Media apps showing things are fine.
I have called customer services, managed to get hold of someone after over an hour on hold, who quickly said there were issues he could see and a new router was recommended. If that didn't work, an engineer may be required. Have paid the £5 next day delivery charge, begrudgingly, in the hope that this will fix the issue quickly, but would like some thoughts on whether it will or not.
For added context, this is a fairly new router (had it around two weeks) and in that time, have had no real problems, bar one instance of a similar loss of internet that a router "turn off, turn on" fixed.
Any thoughts would be hugely appreciated. In the absence of responses today, I will update as and when the new router arrives tomorrow.
Anonymous
Not applicable
Message 2 of 13
Re: Help! No internet connection
The WHAT?!?
danw_2020
  • 15
Message 3 of 13
They gave me the option to have it dropped to a "store" for collection, but said it would take longer. Given that this was deemed to be the fix of my issues, and the fact I'm working from home, like so many, I had to take the punt. Can't say I was particularly pleased to have to pay it, though.
Anonymous
Not applicable
Message 4 of 13
I've never heard of a surcharge for delivery.
danw_2020
  • 15
Message 5 of 13
I've pulled my router data, if anyone would be kind enough to have a look.
11387500003.440256 qam1
2146750000340256 qam2
3154750000340256 qam3
4162750000340256 qam4
51707500003.240256 qam5
61787500003.240256 qam6
71867500003.240256 qam7
81947500003.240256 qam8
92027500003.240256 qam9
102107500003.240256 qam10
112187500003.540256 qam11
122267500003.540256 qam12
132347500003.740256 qam13
142427500003.940256 qam14
152507500003.940256 qam15
162587500003.940256 qam16
172667500004.440256 qam17
182747500004.440256 qam18
192827500004.440256 qam19
202907500004.340256 qam20
212987500004.540256 qam21
223067500004.940256 qam22
233147500004.640256 qam23
243227500004.440256 qam24
1Locked40.3150
2Locked40.370
3Locked40.360
4Locked40.3220
5Locked40.3100
6Locked40.360
7Locked40.3210
8Locked40.3100
9Locked40.9110
10Locked40.3100
11Locked40.3100
12Locked40.9130
13Locked40.3120
14Locked40.3100
15Locked40.9120
16Locked40.3100
17Locked40.370
18Locked40.9160
19Locked40.390
20Locked40.990
21Locked40.370
22Locked40.9170
23Locked40.380
24Locked40.350
Time
Priority
Description
11/11/2020 08:32:28
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 08:24:43
critical
10/11/2020 22:34:8
notice
01/01/1970 00:01:33
critical
10/11/2020 12:37:27
notice
10/11/2020 12:18:10
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 12:18:10
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 12:18:8
Warning!
10/11/2020 12:18:8
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 12:18:2
critical
10/11/2020 12:18:2
Warning!
10/11/2020 12:18:2
critical
10/11/2020 12:02:54
notice
10/11/2020 11:55:36
notice
Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 11:25:26
notice
10/11/2020 11:18:53
notice
SW download Successful - Via Config file
10/11/2020 11:16:52
notice
SW Download INIT - Via Config file
01/01/1970 00:01:39
critical
10/11/2020 10:15:8
notice
10/11/2020 10:01:0
Warning!
danw_2020
  • 15
Message 6 of 13
First time I've called, so didn't know it wasn't a thing. Fingers crossed it restores my internet!
danw_2020
  • 15
Message 7 of 13
Adding my router data, if anyone would be kind enough to share their thoughts on it.
1Locked40.3150
2Locked40.370
3Locked40.360
4Locked40.3220
5Locked40.3100
6Locked40.360
7Locked40.3210
8Locked40.3100
9Locked40.9110
10Locked40.3100
11Locked40.3100
12Locked40.9130
13Locked40.3120
14Locked40.3100
15Locked40.9120
16Locked40.3100
17Locked40.370
18Locked40.9160
19Locked40.390
20Locked40.990
21Locked40.370
22Locked40.9170
23Locked40.380
24Locked40.350
danw_2020
  • 15
Message 8 of 13
1394000004.475512064 qam6
2326000334.5512064 qam7
3462000004.5512064 qam5
4257999954.5512064 qam8
3ATDMA0000
4ATDMA0000
danw_2020
  • 15
Message 9 of 13
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID3428
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID3427
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Z92
  • 2.47K
  • 203
  • 392
Problem sorter
Message 10 of 13
So, they think their equipment is faulty, they asked you to pay to replace it and you said yes?!
That's the first I've heard of VM charging to send out replacement hubs.
