Deluxe_65
Settling in
Message 1 of 5
Help Newbie - connections old cable and wireless box - Broadband
HI Just moved into new place - Virgin Media was previously installed - I have Just signed up for Broadband only. the wall box is old and labelled Cable and wireless - It has two outputs - one tabled TV and one labelled FM.
the TV output already has a cable attached to it which goes out to where the previous owner had a TV the FM has some kind of adaptor on it - both are jammed on  - what do I do?! HELP
IMG_3955.jpeg.
Deluxe_65
Settling in
Message 2 of 5
Re: Help Newbie - connections old cable and wireless box - Broadband
As in do I try and remove the TV cable and attach the Isolator cable will that work or do I need an engineer to install a new wall box?
  • 12.87K
  • 1K
  • 2.56K
Message 3 of 5
You do not need to add the isolator supplied in the kit, as you can see the wall box includes one. The “item” on the Radio socket is a terminator and should remain in place. The cable cable on the TV socket should unscrew with a spanner or pair of pliers, alternatively you could use the existing cable.
Deluxe_65
Settling in
Message 4 of 5
Thanks have decided to use the old cable and its connecting - obvious really! thanks though for the help!
Ashleigh_C
  • 4.16K
  • 167
  • 314
Message 5 of 5
Hi there @Deluxe_65
Thank you so much for your first post to our Community Forums and welcome to the team! It's great to have you here!
Huge thank you to @Tudor for their advise and help on this.
I just wanted to check how things were looking now?
Thank you.
Ash_C
