Murphh
Having issues logging into my HUB 4 router settings
Hi I entered the settings password on the bottom of the HUB 4 into the website (192.168.0.1) to configure my settings and it keeps telling me the password is incorrect and I have typed the correct password in
Anonymous
Not applicable
Re: Having issues logging into my HUB 4 router settings
Sorry for the silly question, however you are using the password and not the SSID wireless key?
Murphh
Hi I am using the router password and everything else that is on the bottom of the router and everything is incorrect
Anonymous
Not applicable
All I can suggest is a full reset of the HUB (Pin hole press for at least 30 - 60 seconds).
