  • 8
Message 1 of 5
Having extra v6 box installed in same room as hub.
Will the virgin installer be able to Ethernet cable connect v6 to hub? Or will I have to use a wireless connection. It’s in the same room and about 7 feet away.
  • 11.26K
  • 764
  • 1.58K
Message 2 of 5
Re: Having extra v6 box installed in same room as hub.
Virgin will set up over wifi and coax, they do not carry 7ft ethernet cables
I work for Virgin Media and my posts are my own opinions
  • 6.05K
  • 447
  • 1.05K
Hero
Message 3 of 5
An Ethernet cable is good for 100m, so 7ft is nothing to worry about.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 8
Message 4 of 5
Does this mean. The installer will provide Ethernet cable and connect v6 to the hub?
  • 6.05K
  • 447
  • 1.05K
Hero
Message 5 of 5
Yes, he has cables but it's a good idea for you to have a length of cat 5e or cat 6 patch cable in case you need to test his cable or to connect another device to the hub, cost is only a few Pounds on eBay.
