on 12-04-2023 20:37
Evening hive mind
Just wondering if you can hardwire the pod back to the hub rather than wifi ?
My hub is in the living room and I have a ethernet cable going through into the hallway from a previous install. Wondering if the Virgin pod can connect via the ethernet cable ? Thought it might give that first pod a bit of extra oomph. Maybe the ethernet out from the pod is out only ?
Thanks for any feedback
on 12-04-2023 21:19
You could put a WiFi Access Point on the end of the network cable.
The VM Pods link via wireless, their Ethernet port is for a devices that do not have in built WiFi, ( but not to connect the Hub )
on 13-04-2023 00:54
I believe you can do it that way, some pods do have 2 Ethernet sockets. Give it a try, see what happens.
