@EddiesBestPlate wrote:
Yes it's reset back into router mode, and cant even go a full 24 hours without having the 5-10 second disconnects of service. Yay.
Wired or Wifi connections? If it's wifi, try splitting the SSID and manually choosing the bands for each wifi device. Also disable the Smart Optimisation on the wifi.
• Access your Hub by navigating to 192.168.0.1
• Login with the default login info (on base of Hub) unless you've already updated it.
• Go to Advanced Settings > Wireless > Security
• Under Wireless Frequency 2.4GHz change the Wifi Network Name (SSID), suggest append _2 to the end.
• Repeat for the Wireless Frequency 5GHz, suggest append _5 to the end and click on Apply changes
• Try to avoid spaces and periods in the SSID names as they can cause issues with certain devices.
