HDU-200 cable from wall?
Kibby89
Hi can anyone please assist? So we wanted to move around our living room a little but the wire coming in from the virgin box on the wall inside going to the hdu-200 splitter is too short. Can anyone advise me what it is and what cable i would need to extend it? I have attached some pictures. Thank you!
It says selcon 3.9 on the silver bit of the cable I think.. 
6 REPLIES 6
carl_pearce
Trouble shooter
Technically you aren't allowed to use any cable other than what's provided by VM.
You'll need to arrange a £25 call out for an engineer to make any changes to the wiring.
-tony-
as above is the company answer - you can find genuine cables on ebay or as an alternative swap what you have round if that works with your new layout
a genuine cable for sale here - https://www.ebay.co.uk/itm/145092409665
____________________
Tony.
Sacked VIP
Hi are all the cables the same then? I just need a good quality coax cable, genuine VM if I can?
No.
jpeg1
Personally I'd take the description of "Genuine" on any eBay product with a very large helping of NaCl.
Where does the seller obtain these VM cables?
Hi Kibby89,
As mentioned above, you would need to ensure the cable is provided by VM. We're not able to send longer cables directly but we can book an engineer visit for you for them to get things sorted. There is a £25 charge for this which would be applied to your next bill generated, after the visit takes place.
I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
Kath_F
