  • 19
Message 1 of 18
Fibre speed intermittent - engineer been already no improvement
Hi, I have just given my 30 day's notice as I only signed up again if VM could get my speed constancy, as I get drop outs all the time and speeds ranging from 108 to 12mb.
Engineer came and increased the speed from the cabinet and gave me booster, but the same issues are here. The Tivo is also very unresponsive at times.
stats:
1322750000-7.237256 qam24
2186750000-1.540256 qam7
3194750000-240256 qam8
4202750000-2.540256 qam9
5210750000-2.938256 qam10
6218750000-340256 qam11
7226750000-3.438256 qam12
8234750000-3.938256 qam13
9242750000-4.238256 qam14
10250750000-4.538256 qam15
11258750000-4.738256 qam16
12266750000-538256 qam17
13274750000-5.738256 qam18
14282750000-638256 qam19
15290750000-6.238256 qam20
16298750000-638256 qam21
17306750000-6.238256 qam22
18314750000-6.737256 qam23
19402750000-9.735256 qam25
20410750000-9.735256 qam26
21418750000-10.235256 qam27
22426750000-10.535256 qam28
23434750000-11.235256 qam29
24442750000-11.534256 qam30
1Locked37.350
2Locked40.3110
3Locked40.9190
4Locked40.31022
5Locked38.9585
6Locked40.970
7Locked38.9230
8Locked38.9180
9Locked38.950
10Locked38.6990
11Locked38.950
12Locked38.9110
13Locked38.9130
14Locked38.670
15Locked38.660
16Locked38.690
17Locked38.670
18Locked37.670
19Locked35.7540
20Locked35.71270
21Locked35.52860
22Locked355860
23Locked3510060
24Locked34.442670
1394000394.45512064 qam76
2461999714.525512064 qam75
3537000004.7512064 qam74
4603000004.75512064 qam73
3ATDMA0000
4ATDMA0000
  • 13.71K
  • 1.06K
  • 3.19K
Message 2 of 18
Re: Fibre speed intermittent - engineer been already no improvement
are those levels after the tech altered them - if so someone needs to have a word in his ear the downstream levels are awful -6 is the minimum - i dont wonder you have problems
@ModTeam can someone get a tech to sort this - indications are tech left it like this
____________________
Tony
  • 19
Message 3 of 18
hello, yes this was after he left.
thanks @TONY and @ModTeam
  • 13.71K
  • 1.06K
  • 3.19K
Message 4 of 18
do you have an attenuator in the line - between the input and the hub - if so remove it and see what the downstream is
Tony
  • 19
Message 5 of 18
not sure what this means
  • 19
Message 6 of 18
i have a white booster connected between the cables and the hub?
  • 13.71K
  • 1.06K
  • 3.19K
Message 7 of 18
a photo would help - but is it a short barrel connector - maybe has a number on it -3 -6 -10 are common - if so its there to reduce the input level to the hub - remove it and look at the downstream levels and see if they have risen
guess work but i would not think a tech would leave the hub with levels like that so wondering if he tested at the cab or the omnibox and missed the attenuator
Tony
  • 1.74K
  • 95
  • 129
Message 8 of 18
Evening ciccone 🙂
Thanks for your post,
I've sent you over a private message so I can get a few more details from you.
Get back to me when you can,
Alex_Rm
  • 5.16K
  • 362
  • 893
Superstar
Message 9 of 18
It will look something like this:
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 19
Message 10 of 18
hello, the engineer came out on Saturday, turns out the cabling in the street has been damaged, Today they were due to fix but I;m still getting poor service,
1394000004.45512064 qam76
2462000004.525512064 qam75
3537000004.675512064 qam74
4602998734.725512064 qam73
3ATDMA0000
4ATDMA0000
