Fibre broadband only available for ground and first floor flats (in two floors building)
Zingeer
Hi. I have been waiting for fibre broadband for many years. Virgin media installed cables in front of my building about 2 years ago.It is a 2-floors building.
The flats on the ground and first floor have fibre broadband available to them from Virgin Media. The second floors do not. I wanted to ask Virgin Media if they could do something to install fibre broadband for me (a secound floor flat). I can't see any way to contact Virgin Media about this.If it makes any difference, I am the owner of the flat.
1 ACCEPTED SOLUTION
Accepted Solutions
goslow
Your issue may possibly be due to a working height limitation VM seems to have in place.
Topics on here often describe that VM will work to first floor level as a matter of routine. Beyond first floor, those seeking installation or repairs often seems to run into problems getting anything done by VM.
4 REPLIES 4
nodrogd
The answer I'm afraid is quite simple.
Virgin Media do not employ heights trained installers. So anything above 1st floor height is unserviceable unless the building is internally wired through the buildings internal comms infrastructure. This is usually done at the builders expense, or by the building management company if its retrofit.
If all you have is external connections I should look for another supplier.
VM 350BB 2xV6 & Landline. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Cable customer since 1993
goslow
Zingeer
I only have access to the internet via a telephone line. I would like to have something faster. I was hoping there would be an option to install Virgin Broadband.
VM-Jon
Hi @Zingeer
Thank you for reaching out to us here, to the community.
Please accept our apologies for the difficulties you are having, I would like to take a look at this for you and see what I can do to help. In order to do so I will need a little bit more detail so I will send you a private message.
Thank you
Jon
Here to help! I'm an install manager helping out whilst working from home. Find out more
