MickDundee
FTTP Burnham on Sea
Does anyone know what roads in Burnham on sea Somerset are having FTTP?
I can't find a scope of the works anywhere and I'm desperate to get off my current snails pace broadband.
  • 6.45K
  • 1.01K
  • 1.59K
Re: FTTP Burnham on Sea
Hi MickDundee,
Have you tried the VM postcode checker to see if anything is showing?  https://store.virginmedia.com/check-your-postcode
You could also try dialling 0333 000 5925 and see if they have any expected time, or alternatively email expansionworks@virginmedia.co.uk
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
