cstavr
External brown cable box needs replacement- cables exposed
The brown  cable box  outside our block of flats has been missing and all the cables are exposed and will be damaged. It's also a hazard as they stick out to a busy pavement.
Could it be fixed please?
Any help would be much appreciated.
Many thanks in advance.
Molly_G
  • 429
  • 24
  • 53
Re: External brown cable box needs replacement- cables exposed
Hi @cstavr,
Welcome to the forums and thanks for your post. I'm very sorry to hear of the situation with the omnibox outside your block of flats - I can certainly get an engineer out to come and fix this for you.
I just need to get some account details to determine your location to get this booked in. I'll send you a private message to do so, just look out for the purple envelope at the top of the page.
Molly_G
