Tintin2
Message 1 of 5
Exterior wall box needs replacing
When Virgin media was installed there years ago an old exterior wall box was used. The cover never fitted properly and would fall oak occasionally over the years. Now it has fallen off and blown away. This has left the cabling exposed to the elements. Any way this can be fixed?
Z92
  • 2.46K
  • 202
  • 392
Problem sorter
Message 2 of 5
Re: Exterior wall box needs replacing
It can be booked in as a low priority job if you call customer services.
Tintin2
Message 3 of 5
Thanks for that. Do you have a number? When I tried to call them the automated system kept wanting to check my line before I could speak to anyone.
Z92
  • 2.46K
  • 202
  • 392
Problem sorter
Message 4 of 5
You can try speaking to someone in retentions on 150 or 0345 454 1111 - "Thinking of leaving" menu option just after 8am and you normally get through to someone who can help you out. Unless you are having a problem with your service however, it could still be a while before it's fixed.
Tintin2
Message 5 of 5
Thanks a lot. Will give it a try.
