Rubix
Extension cable to TV from hub
Hi all
I'm hopefully about to leave Sky for Virgin and have been checking out the self installation instructions. We currently have VM wired into the house in various locations, but none of those are convenient to the TV. We'll be fine setting up the hub from one of these but I note that the video suggests "no more than 3 metres".
I currently use a satellite extension cable for Sky and wondered if it's possible to use one of these from the hub to the VM TV box? We're in a rented house and the TV is on a middle wall so for both reasons I'm very reluctant to have an engineer move it, if it's even possible.
Any advice will be gratefully received.
  • 12.86K
  • 1000
  • 2.56K
Re: Extension cable to TV from hub
You cannot use any other cables than the ones supplied by VM, you will break the T&C and possibly introduce noise into your connection and other people on your street cabinet. It's best to opt for a manned install and the technician can either move the existing wall box or provide a longer cable (a longer cable may need the technician to rebalance the circuit at the street cabinet). if you wanted this done after the installation there would be a fee of £25.
LittleMick73
  • 5.39K
  • 547
  • 924
Superstar
Hi for virgin TV you will need a coaxial cables for the hub as well, which the engineer will supply he or she will run the cable were you want it, ideally your hub being near one of the cable boxes so it could be connected with an ethernet cable
would be better, however if you have a good stable WiFi signal it will work, virgin engineers don't move or install TVs. However they will need to connect an HDMI cable to back of the TV from the boxes. Regards Micky
