I was told they are paid per job not per hour so they spend as little time on each job as possible.
They installed under my hedge and made a complete mess of it, they said they'd be back which I didn't believe and did it myself for a far better solution. They never came back (no surprise there).
If you complain they will come back eventually, but the best job is the job that you do yourself.
