on 21-12-2021 19:12
I have had the new hub 5 a few days now and at the start all was working ok, but now I am getting upload speed drops sometimes as low as 3Mbps and the download can drop to 170Mbps which is not too bad but was allway above 200Mbps. Run the virgin test and it came back as possile noise in the cable. Have checked all connections. Hub in modem mode but is the same in router mode.
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
1 | 307000000 | 2.2 | 39 | QAM 256 | 22 |
2 | 139000000 | 1.9 | 38 | QAM 256 | 1 |
3 | 147000000 | 1.9 | 39 | QAM 256 | 2 |
4 | 155000000 | 1.9 | 39 | QAM 256 | 3 |
5 | 163000000 | 1.7 | 39 | QAM 256 | 4 |
6 | 171000000 | 1.9 | 39 | QAM 256 | 5 |
7 | 179000000 | 2.1 | 39 | QAM 256 | 6 |
8 | 187000000 | 2.1 | 39 | QAM 256 | 7 |
9 | 195000000 | 2.2 | 39 | QAM 256 | 8 |
10 | 203000000 | 2.2 | 39 | QAM 256 | 9 |
11 | 211000000 | 2.5 | 39 | QAM 256 | 10 |
12 | 219000000 | 2.7 | 39 | QAM 256 | 11 |
13 | 227000000 | 2.7 | 39 | QAM 256 | 12 |
14 | 235000000 | 2.7 | 39 | QAM 256 | 13 |
15 | 243000000 | 2.6 | 39 | QAM 256 | 14 |
16 | 251000000 | 2.6 | 39 | QAM 256 | 15 |
17 | 259000000 | 2.6 | 39 | QAM 256 | 16 |
18 | 267000000 | 2.5 | 39 | QAM 256 | 17 |
19 | 275000000 | 2.6 | 39 | QAM 256 | 18 |
20 | 283000000 | 2.7 | 39 | QAM 256 | 19 |
21 | 291000000 | 2.7 | 39 | QAM 256 | 20 |
22 | 299000000 | 2.5 | 39 | QAM 256 | 21 |
23 | 315000000 | 1.6 | 39 | QAM 256 | 23 |
24 | 323000000 | 1.3 | 39 | QAM 256 | 24 |
25 | 331000000 | 1.5 | 39 | QAM 256 | 25 |
26 | 339000000 | 1.8 | 39 | QAM 256 | 26 |
27 | 347000000 | 1.8 | 39 | QAM 256 | 27 |
28 | 355000000 | 2 | 39 | QAM 256 | 28 |
29 | 363000000 | 2.1 | 39 | QAM 256 | 29 |
30 | 371000000 | 2.2 | 39 | QAM 256 | 30 |
31 | 379000000 | 2.3 | 39 | QAM 256 | 31 |
Any help would be gratefully received as I have never had any problems before.
Will post BQM's when I can figure out how to do so.
on 21-12-2021 19:13
Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
1 | Locked | 39 | 69 | 67 |
2 | Locked | 38 | 91 | 68 |
3 | Locked | 39 | 62 | 66 |
4 | Locked | 39 | 122 | 88 |
5 | Locked | 39 | 145 | 111 |
6 | Locked | 39 | 100 | 84 |
7 | Locked | 39 | 120 | 108 |
8 | Locked | 39 | 74 | 87 |
9 | Locked | 39 | 61 | 84 |
10 | Locked | 39 | 49 | 66 |
11 | Locked | 39 | 58 | 59 |
12 | Locked | 39 | 47 | 50 |
13 | Locked | 39 | 55 | 34 |
14 | Locked | 39 | 58 | 47 |
15 | Locked | 39 | 42 | 36 |
16 | Locked | 39 | 32 | 46 |
17 | Locked | 39 | 50 | 29 |
18 | Locked | 39 | 73 | 48 |
19 | Locked | 39 | 53 | 45 |
20 | Locked | 39 | 26 | 45 |
21 | Locked | 39 | 41 | 42 |
22 | Locked | 39 | 46 | 61 |
23 | Locked | 39 | 46 | 18 |
24 | Locked | 39 | 51 | 38 |
25 | Locked | 39 | 59 | 52 |
26 | Locked | 39 | 59 | 48 |
27 | Locked | 39 | 17 | 31 |
28 | Locked | 39 | 20 | 38 |
29 | Locked | 39 | 52 | 39 |
30 | Locked | 39 | 6 | 45 |
31 | Locked | 39 | 0 | 17 |
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 46200000 | 48.5 | 5120 | QAM 32 | 1 |
2 | 39400000 | 48 | 5120 | QAM 32 | 2 |
3 | 32600000 | 48 | 5120 | QAM 32 | 3 |
4 | 25800000 | 47 | 5120 | QAM 32 | 4 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 21-12-2021 19:14
Time | Priority | Description |
20-12-2021 13:55:44 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 13:55:44 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: 2; New Profile: 2 3.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 13:06:05 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=;CMTS-MAC=:cd;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 13:06:04 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: 1 2; New Profile: 2.;CM-MAC=;CMTS-MAC=:;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 13:06:04 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:54:52 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:54:52 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:54:15 | notice | CM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=;CMTS-MAC=:dd:cd;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:54:01 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
20-12-2021 12:53:55 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:52:46 | notice | TLV-11 - unrecognized OID;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:52:44 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:52:42 | notice | Honoring MDD; IP provisioning mode = IPv4 |
20-12-2021 12:52:32 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:52:22 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:52:21 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:39:13 | critical | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:29:11 | critical | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:28:41 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:28:21 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:28:15 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:28:12 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:28:10 | critical | SYNC Timing Synchronization failure - Failed to receive MAC SYNC frame within time-out period;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
20-12-2021 12:27:08 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
17-12-2021 12:35:19 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
15-12-2021 09:04:55 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
04-12-2021 11:49:08 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
on 21-12-2021 19:38
BQM
21st Dec
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/3f80f927b3b997b01fbc44c986f07f0a64c84be3]My Broadband Ping[/url]
21-12-2021 19:40 - edited 21-12-2021 19:41
Upstream power levels quite high and QAM on all four channels 32, when they should be 64:
Looks like a local area issue.
on 21-12-2021 19:54
Also too many Post RS errors which are uncorrectable.
Check with Area faults on www.virginmedia.com/servicechecker or 0800 561 0061 If you have a VM landline 150 The phone goes down to post code level.
If no faults found:
Call Customer Services on 0345 454 1111/150 if you have a VM landline or wait a day or two for a VM staff member to get to your post.
on 23-12-2021 09:41
Latest graph from Thinkbroadband
on 27-12-2021 10:35
Good morning @SNK.
Welcome back to the forums and thank you for taking the time to post.
I am sorry to hear that you are having some issues with your services.
I have managed to locate your account using your forums information, I can see that you already have an engineer booked for this, Is that correct?
Kind regards,
Zak_M
on 27-12-2021 10:59
on 29-12-2021 11:08
Hi @SNK - thank you for getting back to us.
I do hope that the engineer resolves the issue for you tomorrow (30th). Do let us know how you get on!
All the best, Molly.
