colmjude
  • 6
Message 1 of 15
Different wall box for installation
Hi, I received my Virgin Media kit today ready to self install, however following the instructions I noticed the box on the wall is a different type to those mentioned in the instructions. See image.
The white cable coming out the top was connected to a splitter.
I tried to connect the provided cables to the existing wall box
However it doesn't work. Whenever I connect it to the Hub the following happens:
* a red light comes on (the power line light), then blinks, then goes off, then the wifi and internets briefly come on green, the red line comes back on and after a couple of minutes the green lights disappear and I'm left with just the red light.
A connection is never established.
I've called to activate the kit so that isn't the issue.
Does anyone know what could be wrong or how I should be setting up with this old wall box? Is it even possible or do Virgin need to send an engineer out?
colmjude
  • 6
Message 2 of 15
Re: Different wall box for installation
**UPDATE**
I now seem to have a broadband connection but the lights on the hub 3 still don't reflect this. And I'm not sure I'm getting the full speeds I'd expect.
The hub still only has one light lit up; the power line light is red, no other lights are on.
However, I can connect, via wifi, to the Hub and it has a broadband connection.
I have the M200 Fibre Broadband package. But if I do a speed test I get 35mbs down, 3 up. This seems much lower than I'd expect.
Anyone got any ideas what is going on with the hub? And the speeds? Is it to do with the old/weird wall box connection?
Anyone from Virgin picking this up? I'm finding it very difficult to get hold of anyone that is able to provide any information.
Brava210
  • 265
  • 6
  • 42
Fibre optic
Message 3 of 15
If you have a red light, that means the Hub is in Modem mode. Can you reset the router to factory setting?
can you connect to the router with an ethernet cable?
Virgin BB 200, Hub 3, 3 x V6, TP-Link Deco AX20 x1, M5 x2 - United Artists/Telewest/VM Since 1990
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 15
The Modem Mode indication is a magenta coloured base light.
If it was in Modem Mode the Wi-Fi wouldn't work !!
The red light is an indication of the Hub overheating .
The Hub needs replacing.
You can either phone in (08:00 is the best time) or wait on here for a few days until one of the VM Forum Staff comes along.
sayekm
  • 330
  • 29
  • 64
Fibre optic
Message 5 of 15
If you only have internet service you dont need that metal box between the black and white cables joint. You have a in-line isloator on the white cable.
I would remove that metal box and use a connector to conenct the black and white cables without the metal box.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
M200 Oomph - 5GB SIM + 3 extra SIM family plan - BT whole Wi-Fi - Sky Q
Don't cry over Virgin price increase instead speak to retentions team and negotiate a better deal.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 15
The 'Push Fit' connection should be at the Hub and the screw fit at the incoming end.
Z92
  • 2.47K
  • 203
  • 392
Problem sorter
Message 7 of 15
Have you tried adding the splitter again? If it was there before the power levels might be too high to use the connection without the splitter. You don't have to use all three connections as you'll only be using it as an attenuator.
nodrogd
  • 16.82K
  • 1.97K
  • 4.08K
Message 8 of 15
Also a good reason for leaving the existing isolator where it is.
VM BB TV Landline PAYG mobile. Freeview/Freesat HD, Tesco Mobile. Customer since 1993
colmjude
  • 6
Message 9 of 15
Thanks for your reply. I did read that the red line means it is overheating but I'm surprised by because it only arrived on Saturday (so should be brand new) and it certainly doesn't feel hot or even warm.
I'll definitely let VM know and see if they will send me out a new, hopefully not defective, one
colmjude
  • 6
Message 10 of 15
Thanks for your reply @sayekm
I have broadband and TV service so presuming I need both. I could be wrong though
