simzep
  • 5
Connection issues..
Hi, I am having issues with my internet connection. Running very slowly, This has been an ongoing intermittent issue. After many reboots and resets and phone calls., I purchased an Archer C7 router and put my virgin router into modem mode. This seemed to help for a while, but I am now having very similar issues. So could well have been coincidence, hope someone can help me out,as it is very frustrating, Regards Simon..
419000000
Locked
Ranged Upstream Channel (Hz)
60299974
Locked
Provisioning State
Online
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1419000000-3.536256 qam32
2203000000-0.436256 qam9
3211000000-0.737256 qam10
4219000000-137256 qam11
5227000000-1.237256 qam12
6235000000-1.936256 qam13
7243000000-2.436256 qam14
8251000000-2.536256 qam15
9259000000-2.436256 qam16
10267000000-2.236256 qam17
11275000000-2.536256 qam18
12283000000-2.536256 qam19
13291000000-2.436256 qam20
14299000000-2.237256 qam21
15307000000-2.237256 qam22
16315000000-1.937256 qam23
17323000000-237256 qam24
18363000000-2.237256 qam25
19371000000-2.537256 qam26
20379000000-2.737256 qam27
21387000000-2.737256 qam28
22395000000-337256 qam29
23403000000-3.237256 qam30
24411000000-3.237256 qam31
1Locked36.6190
2Locked36.6320
3Locked37.3200
4Locked37.3280
5Locked37.3220
6Locked36.6310
7Locked36.3240
8Locked36.3290
9Locked36.6170
10Locked36.6160
11Locked36.6110
12Locked36.6120
13Locked36.6330
14Locked37.6490
15Locked37.6270
16Locked37.3200
17Locked37.6130
18Locked37.380
19Locked37.3220
20Locked37.3210
21Locked37.6190
22Locked37.6300
23Locked37.390
24Locked37.3130
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
16029997441.8512064 qam9
23940002138.8512064 qam12
34619997139.8512064 qam11
45369998840.3512064 qam10
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0010
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
34ncxv9873254k;fg87dsfd;k
SFID2626
Max Traffic Rate690000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID2625
Max Traffic Rate44000000
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Network LogTime Priority Description
03/11/2020 05:34:25noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 05:33:47Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 00:29:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 08:43:10noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 08:43:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 14:42:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 04:31:45noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 04:31:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 11:38:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/10/2020 23:54:41noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/10/2020 23:54:40ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 00:10:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 11:54:40noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 11:54:40ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 15:42:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/10/2020 03:41:48noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/10/2020 03:41:48ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 00:13:48noticeSW download Successful - Via NMS
15/10/2020 00:11:29noticeSW Download INIT - Via NMS
Andrew-G
  • 6.96K
  • 1.22K
  • 3.04K
Re: Connection issues..
Buying your own router or mesh is usually a good move, but it can only sort out router and wireless matters.  A slow and intermittent connection is usually a fault between the cable modem side of the VM hub and VM's network gear, so I'm guessing that you may have sorted out wifi worries, but you;ve still got any underlying cable problem.
Unfortunately all of your hub's status data is within accepted limits, and the Network isn't show anything that indicates a consistent problem.  There's a solitary upstream T3 timeout which on its own doesn't prove anything (DOCSIS connections always collect a few errors both up and down, what matters is how quicly and what type they are).  Personally I'm unimpressed that your primary downstream channel is at -3.5 dBmV and "only" 36 dB SNR, but those are definitely within the accepted ranges and on their own VM won't do anything about that.  I suggest you do a series of speedtests (ideally from an ethernet connected device) at different times and post the results (both up and down).  Also, set up a Broadband Quality Monitor, let that run for 24 hours and then post a link to shared live graph in a reply here, then we can have a look for other possible causes.
BrianY
  • 727
  • 25
  • 117
Rising star
Also an Archer C7 user but on 200Mb/20Mb.
Although you mentioned rebooting, did this include your C7?
I have found that the C7 benefits from a reboot every couple of weeks or so.
Bad news being that subject to confirmation the maximum throughput is much lower than the quoted advertising.
I would see how the speedtest results go prior to a reboot of both a)Hub 3 and b)C7.
Best of luck.
