SueBeard
Just joined
Connection issue - cable not found
I've been having connection problems lately, too. I can't work properly. I checked the cable, it seems to be intact. But when I connect it, I get an error that the cable is not found.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Xbox one Connection Drop out
You are trying to work using an Xbox One ?
SCA1972
  • 5.89K
  • 662
  • 2K
Re: Connection issue - cable not found
@MikeRobbo The post was originally tagged onto the end of a thread from last year and I moved it here as it appears to have nothing to do with the original thread. I have asked the mods to change the thread subject to something more appropriate, as VIPs can’t edit other user’s posts.
EDIT - I see that the subject has now been edited, thank you @Melissa_F
______________________
Scott
My setup: VM TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
