Connection cable
Hi, I need to move the tv and I need more cable in order to do it. Where do I get the cable from? I need about 7m.
kind regards
  • 15.23K
  • 1.2K
  • 3.58K
Re: Connection cable
you need to get it from VM - its not just a matter of a longer cable - levels need to be checked and adjusted if the longer cable changes things so you need to book a tech
the bad news is it will cost you £99 for a non fault call out - no real way round that
____________________
Tony
Hi Tony,
Thanks... not what I wanted to hear, but appreciate the speedy reply.
Steve
