Hxma
Message 1 of 11
Connecting wires to hub
Hi, I have had Virgin Media before and the wall socket is outside of my house so there is a long wire that comes inside which is supposed to connect to the hub. I have tried connecting it but for some reason it won't connect. They let me pick Quickstart as I have had Virgin Media before but it is hard for me to connect the hub to the wire coming from outside. Please can someone assist me on this.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 11
Re: Connecting wires to hub
Can you post a photo of the white cable end fitting please.
Hxma
Message 3 of 11
Its saying file size exceeds 1mb
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 11
Either ...
Post the photo to a hosting site and put a link to it on here
Or
Use graphic tools to reduce the image size.
Check your PMs.
alexiagilbert
Message 5 of 11
We're having the same issue. It appears that our virgin media box is an old one. Can you help?
Hxma
Message 6 of 11
Can't I just email it because all this seems complicated to me.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 11
Please read post # 4.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 11
It looks like you have been supplied with new cables to connect to old connectors.
You will need to get VM to supply adaptors or different cables.
20200927-131803
20200927-131809
Hxma
Message 9 of 11
They won't answer my phone at all.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 11
Try again in the morning at 08:00
