sbarrac
Settling in
Connecting router to an old multi room connection point
We currently have standard 200mb & phone line connected to a standard telewest connection point in the living room. There's another telewest connection point in an office which I would like to move the router to, but router can't connect using that connection. I'm assuming this connection was a multi-room socket. Is it possible to switch the connections, and use the office access point instead of the living room one?
Anonymous
Not applicable
Re: Connecting router to an old multi room connection point
try it. if it works yes. it not you'll need an engineer to move it at a cost of £99
