Rhiro
  • 7
Connecting laptop directly to Hub 3.0 using ethernet
Hi all, noob here so bear with me pls.
I am trying to use my Hub 3.0 in modem mode. I assumed I could connect my TV and laptop directly to the modem using ethernet cables. However, once the Hub is in modem mode (the light turns magenta so I know it's working) there isn't an internet connection.
I've read in a couple other posts that I may need a router? I'm a bit lost now- can anyone explain what it is I need to do? I just want to get a TV and laptop connected to the internet without using WiFi.
Thank you 🙂
BumbleVMTech
  • 800
  • 139
  • 242
Re: Connecting laptop directly to Hub 3.0 using ethernet
Hi, modem mode deactivates Wifi and DCHP.  The only active port will be the bottom one or Port4.  You would need to connect your own router or DCHP switch to this port.  To Deactivite wifi, log into hubs settings page Advanced Settings > Wireless > Wireless Signal, then disable 2.4 and 5 GHz broadcasts and apply settings.  Take out of modem mode.
Rich
Here to help! Im a Field Technician helping out from home.
Find out more
************ FANCY £50 OFF YOUR BILL ************
****************** ASK ME HOW ******************
paul0363
  • 538
  • 64
  • 180
Rising star
You can connect directly to the Hub using cables in router mode - you don't need to be in modem mode.  If you want to use your own router, however, you'll need modem mode.
If all you want to do is connect to your devices with ethernet then put your Hub back in router mode!
targaid
  • 11
Late to the party but to connect your laptop to the internet via the hub using an ethernet cable you don't want to be in modem mode.
Just plug your ethernet cable from the laptop into one of the ports on the hub and away you go.
