  • 7
happy37
Message 1 of 16
Connecting Sky box to Virgin Super Hub
Hi all,
Just had Virgin Media (broadband/phone line) installed at my sister's place.
She has got an existing Sky TV box but the Net was crap with that so she switched to VM today.
The engineer left instructions to log on to 192.168.0.1 and to then put in the IP address of the Virgin Super Hub into the settings page so that the WiFi can work properly?
Grateful if someone could confirm this please.
Where do I locate the IP address of the Super Hub and the subnet mask too?
If this method doesn't work, the engineer mentioned purchasing a "Sky mini wireless connector" to make things work. Please advise on this too.
Thanks.
happy37
  • 3.65K
  • 201
  • 610
chenks
Community elder
Message 2 of 16
Re: Connecting Sky box to Virgin Super Hub
the instructions don't make sense!
192.168.0.1 *is* the IP address of the hub3
i assume they meant connect the sky box to your WIFI network. if your sky box is less than 5 years old then it should have WIFI built-in.
  • 7
happy37
Message 3 of 16
Hi chenks,
I'm going by what the engineer had said before he left.
I'm going to get some clarification and then I will post back.
Thanks.
happy37
(the Internet is now being supplied by VM and not Sky.) The Sky box only supplies the TV. That's it.
  • 3.65K
  • 201
  • 610
chenks
Community elder
Message 4 of 16
yes, so connect the SKY box to the WIFI network supplied by the virgin hub.
the sky box will have WIFI built-in to allow it to connect to on-demand services.
  • 7
happy37
Message 5 of 16
chenks,
Thanks.
So how do I do this please?
Any instructions to help with this?
Thanks.
  • 4.99K
  • 350
  • 850
Roger_Gooner
Superstar
Message 6 of 16
It's best to connect with an Ethernet cable. If she uses WiFi she may have the option of WPS (perhaps a bit easier than entering the hub's WiFi password).
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 3.65K
  • 201
  • 610
chenks
Community elder
Message 7 of 16
@happy37 wrote:
chenks,
Thanks.
Thanks.
https://www.sky.com/help/diagnostics/connect-to-your-broadband-network/which-sky-box-do-you-have
  • 7
happy37
Message 8 of 16
Hi Roger_Gooner,
That's a lot better.
So does she connect a network cable from the Sky box to the Hub?
Then what does she do?
Thanks.
  • 3.65K
  • 201
  • 610
chenks
Community elder
Message 9 of 16
@happy37 wrote:
Hi Roger_Gooner,
Thanks.
if you are using ethernet, then yes, you would connect an ethernet cable from the sky box to the hub.
then she does nothing, as the box is now connected.
the URL i posted shows you how to connect a sky box to internet - a quick google would have given you that link from sky.
  • 7
happy37
Message 10 of 16
chenks,
Ethernet cable connected.
According to your link, I will have to go in to the settings page and put in the following:-
IP address - Virgin hub?
Subnet mask - 255.255.255.0?
Router - 192.168.0.1?
DNS servers - 194.168.4.100 or Google or whatever?
Please advise.
Thanks.
