Yaasir
Message 1 of 11
Coax cable pin bent
The push-in coax cable on the white wall box popped out and whilst pushing it back in, the pin inside the cable has bent. It is the cable that comes as part of the quick start self-install box. I have tried to unbend the pin and this has caused the pin to snap.
Is it possible for Virgin to send out a replacement cable? I think calling an engineer out to fix this would be costly and unnecessary. I have a generic coax cable which I can use meanwhile to connect but I have heard this can introduce noise into the network so I am hesitant to use that.
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 11
Re: Coax cable pin bent
This will need an engineer to put right or a new cable sent out by VM.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Yaasir
Message 3 of 11
2 months and no response from VM....I guess using my own coax cable is not a problem then!
Z92
  • 2.59K
  • 208
  • 415
Trouble shooter
Message 4 of 11
Can't do that, it's against the T&Cs! You must have no internet until it's fixed using Virgin-quality cable by a Virgin-qualified engineer!
[or make a short term patch whilst waiting for an engineer...]
Anonymous
Not applicable
Message 5 of 11
you waited 2 months and said nothing and then moaned.
If you didn't follow up it can't of been that important
stabilo00
  • 281
  • 36
  • 57
Fibre optic
Message 6 of 11
Think he is making the point that he had to use his own cable because he could not get a response
Anonymous
Not applicable
Message 7 of 11
well he didn't really try
Yaasir
Message 8 of 11
Kindly inform me what else I was supposed to do?
The first reply clearly mentioned not to bump the thread otherwise it would be moved down the priority list, which is thw reason i did not follow up.
Anonymous
Not applicable
Message 9 of 11
you could of replied. Flagged it after a few weeks. Called in. Used the online chat
VM will reply int he next few days (most likely tomorrow)
sayekm
  • 330
  • 29
  • 64
Fibre optic
Message 10 of 11
You be surprised FREE OF CHARGE engineer come round and give you a new cable. The cable supplied by Virgin is damaged and you can't use a 3rd party cable therefore you are unable to receive their service you paying for.
IMO you just wasted your own money buying a 3rd party cable. It maybe an engineer 2 weeks later and normally these guys are very helpful and will leave you a extra spare cable if asked nicely.. they did for me 😉
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
M200 Oomph - 5GB SIM + 3 extra SIM family plan - BT whole Wi-Fi - Sky Q
Don't cry over Virgin price increase instead speak to retentions team and negotiate a better deal.
