  • 33
Check my power levels
What are the range of power levels which you would consider acceptable? I have tried uploading photos of my power levels, but the forum doesn't appear to upload them correctly.
Cheers
  • 3.57K
  • 196
  • 548
Community elder
Re: Check my power levels
Power levels are only one factor that need to be checked.
Large pictures may not upload correctly, and in any case need to approved by a moderator before they can display.  Post just the text using cut and paste, but remove anything private like IP or MAC details..
  • 8
How does one check their power levels?
  • 4.53K
  • 266
  • 524
Hi tom6195
To check your power levels, go to
http://192.168.0.1
Click "Router Status" at the top-right, then click on Downstream. You'll will also see upstream
Post a screen shot of the results here if needed
Gareth_L
