Change Cable Entry Point?
eazbak
Hi all,
I know that this costs £25 and I need to call Virgin but I cannot figure out what options I need to press to get through to someone, can anyone help or can a Virgin Media employee on the forums help me with the process?
At the moment the cable wraps around the house from the front to the back, we have just refurbished the ground floor and I'd like it changed so that it comes in the front as that is where the TV is now located.
Many Thanks, eazbak 😉
2 REPLIES 2
Hi @eazbak
You are right, there would be a £25 non fault call out charge (it used to be £99) to do the work you require.
You should call  150 from a Virgin landline or mobile, or 0345 454 1111, option 2 (Faults
When calling Faults ignore all the options and don't press any buttons then you should be placed into a queue and an agent should pick up the phone and book the tech for you.
Or wait a day or two and a member of the Forum Team should pick this up for you and arrange a tech visit.
Dave
The do's and don'ts.
Many thanks Dave!
