alaamed
  • 6
Message 1 of 12
Cannot connect Coaxial Cable to HUB
Hello Guys, I was told that I had Virgin installation in My new house so I chose self installation but It seems that the coaxial cable to connect to the Hub.
 Any Help please?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 12
Re: Cannot connect Coaxial Cable to HUB
What is the reason that it won't connect ?
-tony-
  • 16.9K
  • 1.32K
  • 3.99K
Message 3 of 12
outside looks ok - inside [sort of] ok - thats certainly an F connector and should screw on but the cable behind the connector looks thinner than i would expect - follow the internal cable back and see what it connects to
also post a sideways picture of the internal connector and cable
____________________
Tony
alaamed
  • 6
Message 4 of 12
It does not allow me to screw it in fully to the hub.
alaamed
  • 6
Message 5 of 12
HUB.jfifcable.jfif
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 12
The central copper wire on the cable needs to protrude by about 1.5mm beyond the nut.
If that is correct and it won't screw in it is normally because the copper wire isn't aligned properly with the centre hole in the Hub.
alaamed
  • 6
Message 7 of 12
it is just I feel that the central wire is a bit thicker than the one in the cable provided.WhatsApp Image 2021-01-01 at 11.23.22.jpeg
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 12
All VM cabling is the same.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 12
That phot shows screw fit and push fit end fittings.
If the cable with the screw fit end fitting comes through the wall directly from the external brown box just connect it to the back of the Hub.
alaamed
  • 6
Message 10 of 12
Thank you so much , It worked when I screwed the end into the hub.
