on 10-09-2021 18:39
I've received my Quickstart kit but the cable doesn't connect to the wall socket. I've tried an adaptor but this hasn't worked either. Is there a specific type of adaptor/connector I need?
Answered! Go to Answer
on 10-09-2021 18:51
That is an old screw type connector. You will have a new push type connector but you should still be able to connect them. Insert the push connector with a firm push.
on 10-09-2021 18:51
on 13-09-2021 11:58
Hi CharleyLH
Just wanted to check in and see if you have been able to get set up?
If not, please do let us know and we will be happy to assist further 🙂
