on 07-03-2022 10:14
Hello,
I have the Virgin Media box that is seen in the picture in my house, but I am not sure if this means I can just purchase a home installation box with the M200 fibre contract and start using it.
Can someone help?
Answered! Go to Answer
on 09-03-2022 12:18
@LPiest wrote:Hello,
I have the Virgin Media box that is seen in the picture in my house, but I am not sure if this means I can just purchase a home installation box with the M200 fibre contract and start using it. <snip>
Not all properties have a socket. Look outside for a brown or grey Omnibox on the wall and trace the cables to the inside. If it is just a cable, you will need one of these to join to the Quickstart cable. https://www.diy.com/departments/slx-f-type-satellite-cable-coupler/5028422001905_BQ.prd
07-03-2022 10:16 - edited 07-03-2022 10:16
Hi there
I can take a look into this for you
We’ll need to look at the serviceability of your property and when it last had service. I’ll pop over a private message to further assist
Christy
on 09-03-2022 11:51
Hi LPiest, thanks for the message. All new lines are 21CV and the phone line would be plugged directly into the hub, do you have any other boxes in the house, it should look like this -
https://community.virginmedia.com/t5/QuickStart-set-up-and/Replacement-wall-socket/td-p/47406
Chris
on 09-03-2022 12:18
on 09-03-2022 12:37
Hi thanks for the response,
The link you sent does not seem to work.
on 09-03-2022 12:38
09-03-2022 13:16 - edited 09-03-2022 13:18
Strange? Works for me. It’s a B&Q F type satellite coupler.
on 09-03-2022 14:14
So sorry I meant Chris's response, yours works fine thank you Adduxi!
on 11-03-2022 15:46
