robinb91
Cable to Socket connection
I was wondering if a cable coupler like this one  https://www.diy.com/departments/tristar-data-cable-coupler/571706_BQ.prd
would make the Virgin push cable fit better into this socket (which is a screw-in). The Wifi's working but it feels there should be a better way to secure it, and not have to worry about disconnecting everytime I accidently step on the cable.
  • 8.45K
  • 674
  • 1.51K
Re: Cable to Socket connection
1) That’s no good it a female to female connector, you would need a female to male connector which is not made.
2) The cable should push on firmly and not be easy to pull off
3) VM’s T&C do not allow any modification to the cabling.
robinb91
Thanks for the reply
Surprise it works however.
Anonymous
Not applicable
You could use a cable clip to secure it to the wall if you like.
