Broken cable and how to connect tv box and hub
Hi guys-
thanks for reading. Yesterday I received my new tv v6 box.
when I attached the new splitter cable to my old hub box the wire has completely spilt apart and the inside wires is now visible! 😱😱😱 is this a common fault?
also I’m not sure I can even use the new TV box as my internet hub is set up upstairs (only place in the house it can go) but my tv is down stairs. How do I connect the two with out them having a 30ft wire running all over my house?
min pribaclt being really dense but I honest don’t see how I do it? Seems I need the Ethernet cable attached to both the hub and tv box?
hope someone can help.
ggrider1
  • 12.06K
  • 939
  • 1.54K
Re: Broken cable and how to connect tv box and hub
You connect the V6 to the VM system using the white co-ax cable.
You then go into the V6 settings and set up a Wi-Fi connection to the VM Hub.
Mike Robinson
Hub and tv no where near each other and broken cable
Broken cable and how to connect tv box and  broken cable
sorry for repeated post- I makes my previous one as answered when trying to reply to an answer. 😩
Hi guys-
ggrider1
  • 15.83K
  • 1.79K
  • 3.68K
Re: Hub and tv no where near each other and broken cable
THREADS MERGED
You can remove the helpful answer from the message using the options menu.
If you need the V6 in a different place to the hub you cannot self-install. Call Customer Services & request a manned install. This should be free as you are installing new equipment.
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
