@JustleeUK wrote:
<snip> Could anyone recommend a cable to run on the outside that would work best with 1gb internet.
An external graded Cat 6a cable will suffice. Any thing over Cat 6a will be a waste of money. Do not use CCA cable if possible, look for solid copper cored,
The "CCA" is copper coated aluminium and the aluminium could degrade outside over time
