Didrikoo
Message 1 of 5
Base light flashing green no connection Hub 3
I just moved into a new property and got my router the other day and followed the setup instructions. After being on hold with customer service for 35min I gave up, and was hoping someone on here could help me. The base light on the router is flashing green and the wifi symbol is a constant green but I have no connection to the internet. I have attached Photos of the outlets I have.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 5
Re: Base light flashing green no connection Hub 3
Take the cover off the box that you have connected the coax cable to and see if there is another cable coming through the wall.
Didrikoo
Message 3 of 5
-tony-
  • 17.69K
  • 1.37K
  • 4.27K
Message 4 of 5
have you rung the activation line - 0800 953 9500
thats pretty old i think - i take it you have tried both outlets
you could remove the isolator - theres one in the cable so its not needed and get one of these
https://www.diy.com/departments/tristar-data-cable-coupler/571706_BQ.prd
if it works you are sorted - if not you need a tech
____________________
Tony
Didrikoo
Message 5 of 5
Thank you, I'll have a go at that!
