@JollyGiant wrote:
I am currently on a 1Gb connection, is there anywhere in the hub settings that report the actual up/down connection rate.
In my old sky hub on adsl i could see the connection settings
This site shows the speed to the HUB over the VM network, as well as the speed to the device:
https://samknows.com/realspeed/
If you connect to the HUB you can select 'Check router status', then the 'Configuration' tab:
