26-09-2021 13:50 - edited 26-09-2021 13:56
Frequently throughout the day the wired PC's and devices linked by WIFI show no connection, this begun Thursday morning.
Using the "Virgin Media What do you lights mean" would suggest everything is fine.
When this just happened I tried to login to the SH2 to get the network logs but was unable to on a wired device! It was only after restarting the SH2 and all connectivity had resumed that I was able to login and get the details.
(I will create a BQM monitor today to track going forward)
First Time | Last Time | Priority | Error Number | Description |
26/09/2021 12:37:06 GMT | 26/09/2021 12:37:06 GMT | Error (4) | 68010302 | DHCP WAN IP - XX.XX.XX.XXX |
26/09/2021 12:36:13 GMT | 26/09/2021 12:36:13 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
26/09/2021 12:36:03 GMT | 26/09/2021 12:36:03 GMT | Error (4) | 68000407 | TOD established |
Time Not Established | Time Not Established | Notice (6) | 84000510 | Downstream Locked Successfully |
26/09/2021 12:34:20 GMT | 26/09/2021 12:34:20 GMT | Critical (3) | 82000400 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
26/09/2021 12:33:52 GMT | 26/09/2021 12:33:52 GMT | Critical (3) | 82000400 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
26/09/2021 12:33:30 GMT | 26/09/2021 12:33:30 GMT | Critical (3) | 82000400 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
26/09/2021 12:31:28 GMT | 26/09/2021 12:31:28 GMT | Warning (5) | 84020200 | Lost MDD Timeout |
26/09/2021 12:31:27 GMT | 26/09/2021 12:31:27 GMT | Warning (5) | 84020200 | Lost MDD Timeout |
26/09/2021 12:31:22 GMT | 26/09/2021 12:31:22 GMT | Critical (3) | 84000500 | SYNC Timing Synchronization failure - Loss of Sync |
26/09/2021 12:31:21 GMT | 26/09/2021 12:31:21 GMT | Critical (3) | 84000500 | SYNC Timing Synchronization failure - Loss of Sync |
Downstream DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) | 139000000 | 147000000 | 155000000 | 163000000 | 171000000 | 179000000 | 187000000 | 195000000 |
Lock Status(QAM Lock/FEC Sync/MPEG Lock) | Locked | Locked | Locked | Locked | Locked | Locked | Locked | Locked |
Channel ID | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
Modulation | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM |
Symbol Rate (Msym/sec) | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 |
Interleave Depth | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 |
Power Level (dBmV) | 5.47 | 5.54 | 5.52 | 5.58 | 5.64 | 5.47 | 5.33 | 5.38 |
RxMER (dB) | 38.26 | 38.26 | 38.26 | 38.26 | 39.40 | 38.98 | 39.40 | 39.40 |
Pre RS Errors | 356 | 316 | 308 | 301 | 320 | 294 | 301 | 290 |
Post RS Errors | 320 | 293 | 299 | 288 | 308 | 279 | 284 | 287 |
Upstream US-1 US-2 US-3 US-4
Channel Type | 2.0 | 2.0 | 2.0 | 2.0 |
Channel ID | 2 | 3 | 4 | 1 |
Frequency (Hz) | 39400000 | 32600000 | 25800000 | 46200000 |
Ranging Status | Success | Success | Success | Success |
Modulation | 16QAM | 16QAM | 16QAM | 16QAM |
Symbol Rate (Sym/sec) | 5120000 | 5120000 | 5120000 | 5120000 |
Mini-Slot Size | 2 | 2 | 2 | 2 |
Power Level (dBmV) | 46.25 | 46.00 | 46.00 | 46.50 |
T1 Timeouts | 0 | 0 | 0 | 0 |
T2 Timeouts | 0 | 0 | 0 | 0 |
T3 Timeouts | 0 | 0 | 0 | 0 |
T4 Timeouts | 0 | 0 | 0 | 0 |
Answered! Go to Answer
28-09-2021 17:35 - edited 28-09-2021 17:35
Hi .@Tom_F So since I reported the issue wouldn't you believe it no disconnects . . .
I have an engineer scheduled to visit on Saturday, if you look at my BQM over the last few days except for some random loss of connection in the early hours it looks ok? If I get to Thursday evening and there is no re-occurrence I can cancel the appointment, or would it be better to still try and swap out?
(Also a cheeky tag to .@jbrennand for the BQM)
https://www.thinkbroadband.com/broadband/monitoring/quality/share/3adc618063924db840f001ba8e92458cfd6289be
on 30-09-2021 18:34
Hi @s71rl2,
Thank you for the update. I'm glad to hear that your services seem to have improved.
If you've decided to proceed with the engineer visit, please do let us know how it goes and if you need any further support from us.
