360 coaxial cable doesn’t fit
Cdrew
So I just opened my QuickStart package to set up my internet and 360 box but the TV coaxial cable doesn’t seem to fit the box. Have I been sent the wrong cable?
13 REPLIES 13
Cdrew
Graham_A
Check through all the packaging that the equipment came in.  There should be a short adapter cable in there, often missed if tucked away in a crevice.
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Please read the FAQs
Hi Graham,
The diameter of both the male and female heads appear to be the same size. So I can’t push them together?
Graham_A
@Cdrew Please refer to my edited post at message 3.
Graham
Hi Graham,
I’ve triple checked the packaging to no avail. Do you know if I can order an adapter to be sent? Do I have to speak to customer services?
Graham_A
@Cdrew I have asked the VM Forum Team staff to respond as soon as possible so that they can get this resolved for you.  They should respond here later this evening or tomorrow.
Graham
Thank you for your help
Matthew_ML
Hey Cdrew, thank you for reaching out and a warm welcome to the community, I am sorry you got sent the wrong size cabled.
I am going to send you a PM, so we can get to the bottom of it.
Please look out for the purple envelope. Thanks
Matt - Forum Team
New around here?
Hi Matt,
Not sure I’ve found your message today about the missing adapter. Could you please send it again?
