PAPRIKA959
  • 28
Message 1 of 10
1GB FIBRE WITH HUB 4 TEST - REQUEST
Hi is it possible for someone at VM to run a test on our IGB fibre connection, since before Christmas we're getting daily disconnects to the ISP from our router.
The VM hub 4 is in modem mode, with the attached router an Asus AX88U, everything was OK until about six weeks ago when we started getting daily (sometimes more than once) connection drops to the ISP. Ive troubleshoot all any possible ASUS router issues and all seems OK as we've not changed anything in recent months.
We can't run a test ourselves as its a Hub4, so any help would be greatly appreciated.
Thanks in advance
-tony-
  • 17.7K
  • 1.37K
  • 4.28K
Message 2 of 10
Re: 1GB FIBRE WITH HUB 4 TEST - REQUEST
you can post the levels - you need to log into the hub 4 and then advanced settings/tools/network status
post the downstream - upstream and network pages
____________________
Tony
PAPRIKA959
  • 28
Message 3 of 10
Hi Tony, many thanks for the reply. Screen grabs attached of the downstream, upstream and network log pages. I've absolutely no clue what any of it means so apologies and many thanks in advance.
Cheers
Nigel T
Anonymous
Not applicable
Message 4 of 10
Could you create a BQM and post the live link?
The HUB stats, that I can make out anyway, look ok.
  • 17.12K
  • 734
  • 1.71K
Message 5 of 10
Do the following:
https://www.asus.com/support/FAQ/1043591/
PAPRIKA959
  • 28
Message 6 of 10
Hi thanks for the reply but the router is already set to 'continuous Mode'
Thanks anyhow
spgray
  • 2.39K
  • 139
  • 341
Problem sorter
Message 7 of 10
my RT-AX88U is set to "agressive mode" and has no issues.
however, i don't believe that setting has anything to do with your issue.
when you say "connection drops", are you talking about a physical connection/sync drop? (the WAN light on the router turns red?)
or are you talking about WIFI connection drops?
My Broadband Ping - spgray
PAPRIKA959
  • 28
Message 8 of 10
Hi there, yes exactly that the wan light on router turns red, we then reboot and it goes back to as it was
Cheers
spgray
  • 2.39K
  • 139
  • 341
Problem sorter
Message 9 of 10
what colour is the light on the hub when the WAN light on the asus is red?
does the hub look like it's resycning?
PAPRIKA959
  • 28
Message 10 of 10
Hi there, no the ring light on the hub 4 stays static white, I haven't noticed any pulsing od said ring light except when we reboot the hub 4.
Cheers
