1 gig broadband upgrade, sent hub 4 instead of hub 5
jonchurchy87
Today was supposed to be the day I upgraded from the 500m internet to 1 gig from hub 3 to hub 5.
When the yodel delivery arrived, all that appeared was hub 4, even though in the contract and deal that I was sold was explicitly for hub 5.
I spoke with a customer service agent earlier who said that hub 5 should be with me on Friday and that an email should be sent out confirming this but I have not had anything, just wondering if hub 5 is going to be dispatched at all, or if anybody else had had hub 4 delivered to the instead of hub 5, as I went for the hub 5, as an upgrade from what I currently have
24 REPLIES 24
I believe the Hub5s are only being sent out to new customers on 1G, not upgrades. This is because of shortages. A VM staff member may be able to help further.
Is it in writing that you would get a Hub 5?  Both the Hub 4 and 5 are the proper Hubs for the 1 Gb Tier.
Thanks for this, yea it’s on my contract for a hub 5
Exact same thing happened to me last Saturday. Upgraded to 1Gbps and got a Hub 4 even though order says Hub 5.
Wanted it for the 2,5Gbps port as I have a multigig router. So 940Mbps instead of the advertised 1130Mbps.
Was given about 5 different reasons.
Yep exact same reason why I wanted the hub 5, at least I am not the only one with this issue
Hey jamesie1979
Dis you manage to get a hub 5 set to you or are you still waiting?
Not yet. Doubt it will happen anytime soon to be honest.
Are you using the hub 4 at the moment? I might wait until Friday and see what happens, not very hopeful though
@jamesie1979 wrote:
It's advertised as 1130Mbps across multiple devices at the same time when using the HUB in router mode.
You'll still get full speeds across two devices for the time being.
