@Chrisevanz wrote:
right thanks for that information i actually don’t know where to read about allow deny and disable to determine the terminology
but what i had done before was have it on deny i’m positive about this but now when i select the devices i want to block like i said it blocks all devices from wireless
I’d hope that there was some detail on the page that you actually implement the settings - at least describing how each behaviour works..
If not, you’d have to do some testing of your own to work out how it behaves... i.e. put just the MAC address of the device you are using to configure the hub in the list, then select deny.. see if you get booted out - then test if you can connect from a different device..
