  • 18
tommannix
Message 1 of 7
wireless booster
when setting up my new wireless booster can I turn off the wired booster after I have gone through the set up procedure ,as I only need a booster in my grandchildren's bedroom upstairs
  • 19.36K
  • 1.69K
  • 4.23K
Message 2 of 7
Re: wireless booster
Don't see why not might need to resync if off for awhile
Click to learn more about VIP
Use Kudos to say thanks
  • 19.82K
  • 2.02K
  • 3.8K
Message 3 of 7
What do you mean? A Wireless booster needs to be paired with a companion Booster that's connected to the Hub. It won't work by itself.
  • 18
tommannix
Message 4 of 7
Will the wireless booster connect directly to the hub once I've completed the set up sequence ??.or it will mean more wires and cables all around the hub .I HATE CABLES
  • 19.82K
  • 2.02K
  • 3.8K
Message 5 of 7
The idea of Boosters is that they use your home power wiring to avoid trailing cable around the home. So you place once in a power socket near your Hub 3 and connect it via Ethernet to your Hub. The other one goes wherever you need the network extension.
But you need to have at least the two for them to work.
  • 18
tommannix
Message 6 of 7
Ok thanks , just a bit disappointed as my home hub is in a unit with no spare plugs or room for another box
  • 19.82K
  • 2.02K
  • 3.8K
Message 7 of 7
The Boosters are pass through though - so you don't lose a power socket:
https://www.virginmedia.com/help/virgin-media-booster-troubleshooting
