  • 6
alyson1
wifi
I have new router but the same problems have started again, if i restart or shutdown my pc the wifi goes off when i go back on pc i run trouble shooter and will various error messages from no gateway or no ip address, i've been with virgin for a long time and sick off phoning and not getting a uk call centre no offence but they cant understand my accent, and unfortunately i think i will be leaving virgin,got this new router as they said my other one was old but the same problems have occured and im really sick of problems
  • 1.11K
  • 50
  • 104
Moderator
Moderator
Re: wifi
Hi alyson1,
Thanks for your post. I'm very sorry to hear you are having trouble with your WiFi.
Are you having any trouble with connection on a wired connection?
Are you having the same issue on any other devices?
Lindsey_C
  • 6
alyson1
Re: wifi
No issues with other devices put in wired cable and still did not have access, the hub is out in the open this problem started about 8 to 10 months ago hence the new hub but now problem is back and as i said in previous post getting different error message how can ip address not be valid or no gateway this is very frustrating, as a result i keep my pc on all the time so problem does not occur only my pc is off is if have too restart pc after any updates
  • 1.33K
  • 71
  • 103
Re: wifi
Thanks for getting back to us.
Do you have any third party equipment that you're using - router/booster etc?
Which hub is it that you're using?
Melissa
  • 6
alyson1
Re: wifi
not using any third party device and its a hub 3
  • 1.09K
  • 50
  • 89
Re: wifi
How is your pc connected to the internet? Via WiFi or wired connection?
Are you able to connect to a different pc/laptop and if so does the same thing happen?
Which Operating System are you using e.g. Windows 10? I ask because it may be a power management setting within Windows that may be turning off your network card?
Regards,
Lisa_CC
