  • 8
Message 1 of 12
wifi problem
Hi my wifi keeps dropping out all the time and booting all sorts of devices off and we keep having to re enter passwords on all these devices including phones , xboxs , alexa and pc keeps saying no internet this is happening all the time and i have done all the online tests including resetting with no fix
can anyone help as every time i ring the call center i spend an hour on the phone and get cut off
  • 11.49K
  • 891
  • 1.46K
Message 2 of 12
Re: wifi problem
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 24.4K
  • 1.4K
  • 3.1K
Message 3 of 12
Re: wifi problem
Are your wired connections also dropping?
  • 8
Message 4 of 12
Re: wifi problem
Hi no wired connections are not dropping
  • 8
Message 5 of 12
Re: wifi problem
All connection have been checked as we had an engineer come and sort everything out last week when we had no internet due to another problem but this problem was doing this before and is still doing it now we have also checked online for problems in our area and comes back with nothing also my neighbors is fine it is just wifi connections
  • 24.4K
  • 1.4K
  • 3.1K
Message 6 of 12
Re: wifi problem
If it's only wifi dropping and not wired connections then the connection as a whole is not going down
  • 8
Message 7 of 12
Re: wifi problem
The wifi connection goes down as a few devices loose connecting to the router at the same time
  • 24.4K
  • 1.4K
  • 3.1K
Message 8 of 12
Re: wifi problem
What hub do you have?
You can try and optimise the wifi (splitting the bands, changing to a less congested channel etc etc), failing that you'll need to invest in a better router or mesh system to improve you wifi coverage and connectivity.
  • 8
Message 9 of 12
Re: wifi problem
its the hub 3 ive got no more connections than when i got the router and it used to work fine so surly the router is failing ?
  • 24.4K
  • 1.4K
  • 3.1K
Message 10 of 12
Re: wifi problem
Not necessarily. It doesn't take much for wifi to get knocked out, especially on cheap ISP kit.
