on 15-01-2021 14:12
ok-plug and play it says
white light on pod just keeps flashing white
been plugged in for 30 mins
will not connect to hub
hub has latest firmware
any ideas??
on 15-01-2021 16:53
@jb66 wrote:I'm at a loss how it's possible to just be plug and play, how on earth does it know what your SSID and password is?
WPS ?
on 15-01-2021 16:55
NOT a new hub
had a few months
was updated software
rolled back on its own today
on 15-01-2021 16:57
no wps
must be linked to hub when sent out
on 15-01-2021 17:02
@apj_uk wrote:Hi,
I am in the same boat. I noticed that the new firmware ( 01.02.065.21.EURO.PC20 ) removed my separate 2.4 & 5ghz channels that I had previously setup and it had also reactivated the dreadful Smart Wifi channel optimisation setting.
Aidan
not sure if the official release has changed anything but those settings were required in the trial - so i guess you need to start at that point and change things and see if the pods continue to work
on 15-01-2021 17:04
15-01-2021 17:06 - edited 15-01-2021 17:06
So does that mean you have to use the hub default SSID and password? I can see that going down with some people.
on 15-01-2021 17:06
on 15-01-2021 17:09
@gary_dexter wrote:
What a bizzare way of doing things. So whenever you have a hub swap you need to ensure the config on the pods are also updated to sync to the new hub.
What a load of hassle, just waiting to go wrong
there is no config on the pods - was you not on the trial - if not you need to get up to date to comment surely
on 15-01-2021 17:10
@legacy1 wrote:So does that mean you have to use the hub default SSID and password? I can see that going down with some people.
no - were you not on the trial - if so you would have known
15-01-2021 17:21 - edited 15-01-2021 17:24
Its why I'm guessing😁
So the pod must be pre config knowing the hub AP MAC? then makes a encrypted connection to ask for the SSID and wireless password?
Or does it take any wireless signal and re-transmits it?
