  • 14
Message 1 of 12
wifi issues
Hi all i was using home plugs they were working fine downstairs but would drop off upstairs i replaced these with DECO TP LINK wifi units a few days ago  my son was playing xbox last night and they continually drop connection tried virgin wifi and had the same problem,  does anyone have a better solution.  Many thanks
  • 14
Message 2 of 12
Re: wifi issues
just to add the xbox is in the next room to the modem. thanks again
  • 11.65K
  • 1.19K
  • 1.88K
Message 3 of 12
Re: wifi issues
My lad who believes wifi is the work of the devil, uses a pair of (Solwise) powerline adapters which have 2 ethernet ports. One wired to the router and the one in his bedroom is connected by short Cat6 cables to his gaming PC and consoles - all works flawlessly. I would get those types instead of relying on wifi.
  • 14
Message 4 of 12
Re: wifi issues
hi  thanks for the reply    the problem i have is that the modem is in the dining room but i also need to get to 2 tv's upstairs and my wife hates to see cables.
  • 11.65K
  • 1.19K
  • 1.88K
Message 5 of 12
Re: wifi issues
Use 3 powerline adapters then
  • 14
Message 6 of 12
Re: wifi issues
are powerline adaptors the same as homeplugs ?
  • 11.65K
  • 1.19K
  • 1.88K
Message 7 of 12
Re: wifi issues
I think "homeplugs" is a proprietary term compare them to these
https://www.techradar.com/uk/news/the-best-powerline-adaptors
https://www.techadvisor.co.uk/test-centre/network-wifi/best-powerline-adapters-3490638/
  • 14
Message 8 of 12
Re: wifi issues
prior to going completely wireless i was using tp link homeplugs downstairs with little to no problems atall however upstairs was a different story and i read somewhere that if your electrical wiring is on different ring's ie 1 ring upstairs and another downstairs you will have problems, which i imagine is the problem i have.  thanks again for the advice.
  • 913
  • 137
  • 445
Message 9 of 12
Re: wifi issues
That is indeed true, powerline can be problematic across different rings.
You could try a meshed WiFi system similar to the BT WholeHome WiFi. I’d suggest if you want to give them a go, to purchase from a supplier who has a no-quibble return policy just in case. WiFi can be a bit hit and miss as well at the best of times.
  • 14
Message 10 of 12
Re: wifi issues
hi  i purchased TP link mesh from amazon and on the day i put them in i had the problem i haven't had the problem since (roughly 4days)  so i am now wondering  whether there was a problem with virgin that evening i will just have to wait and see.
