  • 128
  • 5
Dialled in
wifi connection issues
hi, I've got problem connecting to my wifi. firstly can't connect ps4, this has only recently happened, connected fine before and it connects using my phones hotspot.
also my robovac won't now connect again only recently and again will through hotspot.
anyone any suggestions? phone, tablets & tivo all connected ok.
thanks
  • 11.36K
  • 888
  • 1.45K
Re: wifi connection issues
You may be as well refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Instructions for Hub 3
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name [SSID] > Add 5 to the 5 GHz Channel name [SSID] > Click ‘Apply Changes’
Log out of the Hub then reboot using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your Wi-Fi again.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
When you connect the devices do it at the furthest point from the Hub that the device will be used.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 24.31K
  • 1.39K
  • 3.09K
Try a 60 second pinhole reset
  • 128
  • 5
Dialled in
hi guys thanks for your help. tried both adding 2/5 to ssid  and resetting but still not connecting. tv, phone, v6 all ok but not others.
can't understand as both were working ok before.
one thing I noticed the psu cable has a label attached saying 'only to be used with hub 2 or hub 2ac! I've got hub 3 but it's been working fine for a year.
