Message 1 of 5
weak security on IOS devices - no wifi connection
I've got no wifi connection at home on my iPad and iPhone (both on IOS 14) and it shows Weak Security on both devices. I've tried to connect to my Hub 3.0, however when I enter the password from the router it says that the password is not correct (I've tried both password at the bottom of the router.
What are the solution to access to the router settings to change to WPA2-PSK if the password to access is not working?
I'm working with my iPad at home so I need a fast solution.
  • 24.94K
  • 1.44K
  • 3.17K
Message 2 of 5
Re: weak security on IOS devices - no wifi connection
https://community.virginmedia.com/t5/Networking-and-WiFi/iOS-14-Weak-Security/td-p/4410050
  • 5.48K
  • 616
  • 1.82K
Message 3 of 5
You can do a pinhole reset of your hub to make it use the default settings and passwords as per the sticker on the bottom:
https://www.virginmedia.com/help/virgin-media-reset-your-hub
The help page above says to press the reset button for 10 seconds but anecdotal evidence on the forum suggest you might need to press it for longer.
______________________
Scott
My setup: VM TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Message 4 of 5
Thanks for your reply, however the password to access to my router settings (at the bottom of the router) is not working.
how can I change it or access to the settings if the password is not working?
thanks
Philippe
Message 5 of 5
okay thanks, I might try that then
