rds
  • 8
Message 1 of 5
using 4G or 5G failover on virgin router
Is it possible to set up a virgin hub 4 so that if the cable broadband goes down it will automatically switch to 4G or 5G as per the BT/EE set up.
  • 1.95K
  • 126
  • 457
Super solver
Message 2 of 5
Re: using 4G or 5G failover on virgin router
This is not functionality that any of the VM Hubs offers.
I'm sure someone has constructed a solution that does what you describe.
  • 13.91K
  • 1.08K
  • 2.82K
Message 3 of 5
It’s either do it manually or buy your own router that has this functionality and run the VM hub in modem mode.
jpeg1
  • 7.57K
  • 391
  • 1.48K
Message 4 of 5
As @Tudor said, get yourself a router that supports failover.
You can either get one that has a second WAN input for a 4g/5g dongle, or one with a built in cellular facilitity.  Draytek make both, but I'm sure there are others.
I prefered the separate 4g device because it allowed me to site it in the loft where it gets a better signal than at the router's location.
A couple of days ago I found the Virgin phoneline wasn't working. A glance at the BQM showed that the broadband had been down for a few hours. I had been working on line and with a Zoom call and hadn't noticed.
  • 6.82K
  • 593
  • 1.79K
Message 5 of 5
+1 for the Draytek.  That's what I use, except it's VM & BT running concurrently.
